ron hartman
mobile home.......looks like the tub drain assembly has been replaced at one time as there is a hole in the sub floor that wasn't covered up. The drain assembly is brass.. the p trap is plastic...my wife wants the flange and the overflow plate to be brushed nickel... there are no leaks...looking at the shoe from under the home, it looks connected to the fiberglass hole real tight, and i cannot see a rubber gasket there. so i am thinking when i remove the tub flange from above , there won't be enough room to fit in a rubber gasket unless i can get some room between the shoe and the bottom of the tub. If so, how about if i loosen the two screws of the overflow plate just a little bit to see if the shoe then has room for a gasket. i don't want to loosen the screws too much beecause the the plastic p trap would have too much pressure on it to hold up the brass assembly. thanks much !!
