Carson1919
Hello everyone, newish to the forum but learning a ton during my remodel via the old posts and internet. Anyways I ran into a snag. I am redoing my bathroom and have a ranch house with an unfinished basement. All plumbing is accessible from the basement. I have an existing galvanized 1.5" laboratory drain that is 3/4 full of crud that I want to replace. I drew up some existing photos to show the layout and what not. Here are my three options I come up with but would like advise:
Option 1:
Cut an access hole on the backside of the stack, attempt to unthread the existing galvanized pipe. If I can get it out, replace with PVC threaded fitting and run new 1.5" PVC line in existing spot. This seems easy in theory but I'm worried about unthreading existing pipe and also would rather not patch the hole to access the bushing. I also would not have access to tie in point in future. This line is 5' to the stack so it provides the vent. I would rather not use a shield coupler if I don't have too.
Option 2:
Run a new 1.5" line to the 2" shower line. Tie into the shower line with a 2" combo wye and add a AAV underneath the sink. This would then give me a vent and new drain line, however, it sounds like most people do not like the AAV.
Option 3:
Run a new 1.5" line to the 2" shower line and tie into the shower line with a combo wye. The run a "island vent" behind the drywall and couple this into the existing 1.5" galvanized line for the vent. This seems like the best solution to me as long as this will provide the proper vent and drainage for the sink.
Thoughts?
Option 1:
Option 2:
Option 3:
Thoughts?
