hhcibtpaun
If you have only a single horizontal drain, and the laundry sink connects to it with a horizontal combo, then a vent just downstream of that combo could vent both the standpipe and the laundry sink. The vent would have to be close enough to work for the standpipe if the laundry sink weren't there, i.e. within 2" of fall of the outlet of the 2" standpipe trap. This is something the IPC allows called common venting, for any 2 fixtures).
Chapter 9 Vents: Vents, Pennsylvania Plumbing Code 2018 | UpCodes
UpCodes offers a consolidated resource of construction and building code grouped by jurisdictionup.codes
Cheers, Wayne
Thanks Jeff and Wayne.
Wayne,
I played around with my image from above (I will mock up for real in the next day or two). Here is my cobbled together image:
I am a tad confused. When I read this "...a vent just downstream of that combo could vent both the standpipe and the laundry sink...". I was thinking the green line would be the location. After reading this "...The vent would have to be close enough to work for the standpipe if the laundry sink weren't there, i.e. within 2" of fall of the outlet of the 2" standpipe trap...." I was leaning to a vent in the red location...
The orange box is where the sink would be.
Also, for the vent, would I just use a WYE? Finally, is this a horizontal combo?
Thanks...Mike
