I have a bathroom sink that won't drain past the P trap. It happened out of nowhere. I did the Draino trick, didn't work. Then took about the P trap and cleaned it. No success. Also snaked the line, and found some clog but nothing major. The water for some reason sits in the P trap and will not drain into the main line. Any suggestions?
How far did you snake?
I got a RIDGID PowerSpin Plus
I powered it with a drill.
I bought it for a bathroom drain, and it worked great for me. I actually went through the 1-1/4 trap, and before I knew it, it had played out about 12 ft of snake, and the blockage several feet below the santee had been cleared. I was prepared to enter at the trap adapter on the santee, but thought I would try the lazy stay-dry top entry. I know it has limitations.
I only snaked through the trap in case it worked. I was expecting to have to do more disassembly. It was really handy to be able to run water during the snaking. You have some major turns before you even get to your trap.
You may want to call a drain cleaning specialist. Do you have a vent on the roof over the lavatory? If so, the drain cleaner may stick a big cleanout snake down the air vent.
