Bathroom sink drain tie in.
AndyH
Mt. Carmel, TN
I am remodeling my upstairs bathroom and I am putting in a double vanity. I was wondering if I can just tie in to the drain line with a tee either right above or below where the other sink ties in? Here is a picture of the current setup.
Breplum
Licensed plumbing contractor
San Francisco Bay Area
Yes, you can add a tee, preferably to the 2" section of drain.
Also know, that we usually use no-hub couplings when cutting in sections. So much easier than trying to move the unmoveable.
Almost same effort and you could also cut in a double fixture tee we call a Figure 5 (NOT a Double tee!).
The 1-1/2" elbow, if you use one, must be a long sweep elbow.
AndyH
Mt. Carmel, TN
Thank you! Are the no hub couplings you are talking about rubber with hose clamps? Also on the water supply lines would it be acceptable to put a tee after the valves and run flex lines to each sink?
