James Stang
Hello,
I've been lurking on the forums, reading and trying to absorb as much knowledge as I can.
I'm wondering if anyone out there can tell me if my plan for the situation I'm facing in my bathroom remodel is correct, or if you have suggestions for how to do it better, or different fittings to use.
I've included pictures of the current alignment - which has been working with no issues, despite only using a single vent for 3 fixtures (the main stack).
I'm remodeling the main floor bathroom - a 3/4 bathroom (sink, toilet and stand up shower). We do have another full bathroom upstairs, but that is all. This is also the bathroom guests use and see, so I'm hoping to update it to current standards and have it be quite nice. I have purchased an in wall toilet (Geberit frame and Duravit Toilet) and I'm looking to increase the shower from a 34" x 34" to a 48" x 34". This will solve space issues as well as the bathroom being pretty tight.
Now to the current layout.
The main vertical stack goes up to nearly the roof and then turns immediately out to the single floor attic space and then turns up and vents out the roof. There are no other fixtures using this stack to drain above. (The house is a 1 and a half story - so half the house is only 1 story).
The sink and toilet are on one wall and the shower directly across from the toilet. The sink drains straight sideways to the main stack and also vents that way. The washer vent also comes across the basement (6 feet) and then up and vents into the main stack. (You can see beside the toilet)
Below in the basement - you can see the main stack (with cleanout) comes up and angles over and then up again. From that point on, the toilet drains into the stack (no other vent and uses a Y). The shower then runs across (6 feet) and drains into the main stack above the toilet connection (no other vent and uses a Y).
Then above the floor, you already know about the sink drain and washer vent.
See my reply below for the plan, as I have updated it (January 2nd).
Thanks,
James
Thanks,
James
