Joey Leavitt
Through previous help on this forum, I have two proposed options for my new basement bathroom plumbing. Could someone please provide some feedback on a couple items?
- Which option is better, if either?
- For Option 1, there will be about 10" vertically between the closet bend and flange. They only make closet bends in 3->4 from what I see. How would this work? My pipes are 3", so do I use a regular 90? Then 3" stub for a 3" closet flange pipe connection? Or do I use the 3->4 closet bend and stub with 4" pipe to a 4" flange pipe connection (this seems as reducing in the direction of flow technically)?
- For option 2, is it okay to have the toilet draining into the vertical combo as I have shown? This case would also end up being small 3" stub to 3" flange pipe connection.
- For both options, is this the appropriate wet venting layout to an AAV at the Lav? There are no vent stacks in the basement, only waste/soil stacks from upper levels.
