Bath/shower tile question -soap dish reattach repair
Discussion in 'Shower & Bathtub Forum & Blog' started by Onokai, Aug 25, 2020.
  1. Onokai
    Onokai Member
    Apr 19, 2012
    Arcata,Ca
    I made my own tile in the 80s super high fired stoneware. The soap dish was a typical mid 80s white cast off the wall soap dish.Just holds 1 bar of soap in the middle of the battub about 6 inches off the tun rim in middel of wall (full 3 side suround tile in cast iron tub /shower combo. Two days ago after 37 years it fell off the wall into my wifes hands. Its is intact and it looks like I must have thin set it in then grouted around it.(best guess) The orginal price of 4.99 still on the back.
    whats the best way to reattach it. If I thin set again it will stick out to far.All the grount is still stuck to tile. I'm thinking a thin epoxy like JB weld marine or west systems expoy. Something very thin.Then cualk around it to water proof it.?
    any suggestions on a better way.
    The backer board was called wonder board back in that day.
  2. dj2
    dj2 In the Trades
    Aug 13, 2013
    California
    Grind the excess thinset off the soap dish and clean the thinset off the wall with a chisel. Do it carefully.
    Then you will have space for new thinset.
    Find a way to support the soap dish until the thinset is hard enough to hols it in place.
  4. jadnashua
    Bisque ceramic is really porous, and even with the glaze can absorb a lot of moisture...this can pull too much moisture out of the thinset prior to it curing (curing cement is not drying...it's a chemical reaction initiated by the water which gets literally incorporated into the cement as it cures).
    ON a shower, neither the grout nor tile is considered the primary water protection for the structure, so just make the bond good, and either caulk the joint or if you think there's enough for grout to bond to, you could grout it.
    A rubbing block or chisel should get any excess mortar off of the wall and the soap dish.
Similar Threads: Bath/shower tile
Shower & Bathtub Forum & Blog New bath/shower face vet leaking Aug 1, 2020
Shower & Bathtub Forum & Blog Help with strange Symmons Temptrol Bath/Shower valve (video)... Sep 15, 2017
Shower & Bathtub Forum & Blog Converting handles and/or valves on old pfister price bath/shower faucet Apr 17, 2017
Shower & Bathtub Forum & Blog Identify Bath/shower Fixtures Apr 27, 2016
Shower & Bathtub Forum & Blog Is there a problem with this bath/shower installation? Mar 21, 2016
