I don't know the dimensions, but try reversing the one you have.Is there a shallow, non standard or reversible trap that will free up 1 1/2" or so?
Yes, and no. While that asymmetry in the U-bend has a purpose, it is not a big effect. Turning that around is the way you make that trap reversible. You know your bag is labeled reversible.Thank you.
Height wise, that would work but aren't these engineered for specific installation?
You successfully avoided what some others had to deal with.I got into this dilemma by trying to gain a little more space in the cabinet.
The vanity is on legs with drawers between the floor and the cabin.
If you are saying the metal is hitting the white, you can cut that metal shorter. You could even just bend the part
below to the side (into an L) to not hit the white plastic.
I think you are saying that the trap puts some force to the left or right onto the tailpiece.
Unless the U-bend is at right angle to the trap arm, you could adjust to get rid of the stress. Do you follow?
Maybe take a photo looking straight up from beneath. I hope the lens is wide enough to show the trap, trap arm, and the nut at the wall.
Unless the U-bend is at a right angle to the trap arm, you could adjust to get rid of the stress. Do you follow the bit about the right angle?No leaks but I noticed the tail piece is out of plumb 3/8".
If that is the one with the stress, you just need to push the trap arm in or out a tad. All stress gone. If the trap arm is too short to pull out, get a new trap.The trap arm is in straight line with the trap.
