I would like to add a laundry utility sink to our basement (under the window in the picture) along with connections for a washer/dryer (to the left of the sink) and wanted to check on my plan here. The vertical stack that you see in the picture goes up to a kitchen sink. It wouldn't be easy to run a new vent or tap into the kitchen vent higher up without taking apart a lot of the kitchen wall, so I would want to use an AAV. I have easy access to hot & cold water lines that run across the top of the picture.
I think what I would want to do is:
- Cut out a section of the stack, and use two shielded couplings and a (sanitary tee or wye?) to connect to a waste arm
- Put an AAV somewhere between the P-trap and the stack (using a regular tee)
- Is it better to do a separate standpipe for the washer or should I just plan to have the washer drain into the sink?
- I think the stack is 2" cast iron so I will want 2" PVC drain pipe correct?
