Basement plumbing
Discussion in 'IPC Plumbing Code Questions' started by Brunstown, Apr 4, 2019.
  1. Brunstown
    Brunstown New Member
    Apr 4, 2019
    Alabama
    5E58AB3B-6B8D-48A2-8E64-54ED46E19B1B.jpeg Everything in red is what exists. My plan is to wet vent the bathroom groups through the new 3” Vent stack. The issue I’m running into is toilet placement because toilets are supposed to be at end of run. If I tie the toilet in the new location into the 1.5” existing vent and run the drain straight through , will the wet vent then work properly serving both bath groups? IPC here.
Similar Threads: Basement plumbing
IPC Plumbing Code Questions IPC minimum depth to drain pipe under basement slab Wednesday at 3:22 PM
IPC Plumbing Code Questions Drainage Water Test in Basement pre-slab rough-in Tuesday at 10:06 AM
IPC Plumbing Code Questions Basement Bathroom - Single Vent Jul 13, 2020
IPC Plumbing Code Questions Basement bathroom - struggling for layout ideas Apr 9, 2020
IPC Plumbing Code Questions No Future Vent In Basement--Where do I vent Toilet, Sink and Shower Mar 3, 2020
