Muzzlehead
I am tying into a 4" Cast Iron soil line running under my concrete slab. The soil stack serves an additional bathroom (8 FU) located on the first floor and vents out the attic through 3" galvanized steel.
Questions:
1) Overall plan; any problems?
2) Should I vent to the attic with a 3” or will the 2” suffice (easier to get into wall). I have two 2” vents tying together above the vanity and running from there to attic.
3) Is there a max distance for the trap off the shower? I would like to set a clean out over the far end of the trap just behind the toilet in the floor.
4) Do I need an additional clean out after the toilet/tub junction?
Black line = Soil Stack
Green line = new branch; solid and dotted is 4” single green 2”
Red line = Vent; all vent 2”, tub vent ties to sink vent <6” above sink and runs to attic to tie into main
Soil stack 3” vent
All angles on DVW are sanitary T or 45 degree angle
All vent angles are sanitary T or 90- degree angle
All pipe run at @ ¼ inch grade toward main soil stack; 2” DVW ties to 4” branch at 45 degree angle with sanitary t
Helpful Plumbing Hints for Residential Construction by Bert Polk Plumbing Inspector Lincoln County
Questions:
Soil stack 3” vent
