Andrew Gibbons
Flow control or just a check valve?
yes. only one circ. pump, 3 Taco zone valves, hot water baseboard.Is this system only have one pump and might be a floor radiate?
Flow control valve
wrong
It is NOT A flow control valve It is a valve to (manually) adjust how much volume goes to each zone normally installed on the return
A "Flow control" is used to prevent stratification of the hot water rising uncontrollably .
Decades ago fitters used over sized the piping knowing hot water rises and cold water being denser causes circulation without any mechanical means
BUT as fuel costs have risen as well as materials plumbers reduced the piping diameter and used a circulator to circulate the water BUT to prevent heated water from rising when the thermostat did not call for heat a "flow control valve" was installed and o prevented hot waterrising until the circulator came on and over came the weight inside the CV
<<<<<<<<<<<<<<<<< This is a FLOW control valvvalveUOTE]
Schematics. B&G calls their valve you show Flo- Control used like you stated. Balancing valve is a circuit setter with ports for pressure drop and a chart showing pressure drop to gpm that that is built more like a globe valve that has linear flow and not like a ball valve. Thats why i called it a flow control valve and not a balance valve.
