For the past few years I've been living in this house I had to change the pressure switch more commonly than normal. We have bought a new pump, a new tank, and most notably the switch. I've had professionals install everything.
I considered it normal until recently when I was told pressure switches shouldn't go bad every 3-4 months. I tested the pressure in the tank and that was at 28psi, which is expected. The voltage to the pump is at 120ac. Upon further inspection I watch as the switch turns on, and most of the time it sparks and makes contact, occasionally bounces on and off; and sometimes it will trigger and do nothing, contact is made but doesn't switch on. Is it that I may have had a bad series of switches (doubt it) or is there something else wrong?
TL;DR Pressure switch fails every 2-4 months
- Utilitech 36 Gallon Vertical Pressure Tank, 2-3 years old
- Gould's J7s 3/4hp water pump, 2-3 years old
- 30-50 Square D pressure switch, 1-2 months old
