Backyard drainage improvement
patryk
FL
Hi. I want to renovate my backyard in Florida and install a fence. It has a seawall and a canal in the back. The first step would be to improve the drainage and prevent erosion. Then I want to flatten the ground a bit, extend the paved patio, add garden beds and lay artificial grass with gravel base.
The red lines are the drainage pipes and the yellow arrows is the slope direction.
Could you please advise if the attached drainage plan is okay or if there's anything you would do different?
Are the perforated corrugated pipes along the seawall fine (socked with gravel geotextile fabric) or would you do solid perforated pipes? If so should I lay the holed facing up or down?
Thank you
