Nare Bhushan
N B
I have an alpine ALP 105 heating indirect water heater tank. This boiler is proving to be very unreliable, it worked great for first 2 years but now breaking down almost every now and then. Whenever it break down it, it's very tough to go without showers. It takes days to get some tech or parts to fix it. I am fed up with this, I am considering having a backup electric or gas water heater installed. I would really appreciate any suggestions. I can think of few options-
1. Remove indirect water heater tank completely and go with regular hot water heater. Since the boiler will be used only in winter instead of all year around, will it reduce regular wear and tear and frequent breakdowns?
2. Add new heater in series with current system, if for some reason indirect does not work, the regular with heat water automatically? Is it even possible?
3. same as 2 above except instead of series, have it connected in parallel, either use indirect or regular? switch between them using some kind of valve.
My primary aim is to have reliable hot water source, and not to be at mercy of these technicians. The company which installed my boiler want to charge me $250 as just emergency dispatch fees, labor and parts extra. It's ridiculous.
