Themp
Active Member
I replaced our water heater a year ago with a Rheem conventional water heater. It's vent was shared with a gas 80 percent efficient furnace(electronic ignition), which uses a 8 inch flue chimney. The flue is a fired clay 8 inch tile and is dedicated just for the furnace and water heater. At the time of the water heater replacement I noticed that it would backdraft for around 30-60 seconds. I had the gas company come out and they tested everything for CO2 and it showed no leakage even when backdrafting. The gas tech person felt that this was acceptable and his only recommendation was to have a CO2 detector in the basement. I actually have them everywhere in the house. The vent is 16.5 feet of 4 inch type B to a 6 inch type B flue, 7 feet to the chimney. The chimney flue is 25-30 feet.
I just recently replaced the furnace with a 90 percent efficient one and therefore the water heater became orphaned(as they say) on the vent. It now backdrafts much longer, minutes now. It actually melted the plastic rings around the water inlet/outlet. So, I do need to correct this condition. My question is should I line the chimney with a metal liner, they did this for the furnace in attic that was replaced(it has it's own flue). Or go with a direct vent or power vent water heater. Not sure about a tankless at this point. I do like that we have hot water on a power failure. The direct vent water heater would have to be moved to where the basement utility sink is(horizontal vent would be to long for where the water heater is now) . I assume the power vent water heater could be where the current one is. Here are pictures of the the current setup:
https://www.dropbox.com/sh/eeqicw26t2r9egf/AABNa0-Tof_hmzx6wsoQ0kWJa?dl=0
Thanks for any comments, Tom
