Would appreciate any education on this topic. Went to replace a dead tank water heater in our church. Easy to isolate on the cold side. Seeing some back pressure from downstream on the hot side.
Water heater supports a church kitchen and is set at 140 but since it also supports a number of hand sinks, each hand sink has an aftermarket anti-scald mixing valve, thermostatic type.
I am assuming that when there is no hot flow, then cold can backflow from the cold line through the mixing valve and backwards through the hot supply line to the water heater.
Is this normal behavior for an anti-scald mixing valve or does it mean one of more our ours are defective?
Thanks,
Chuck in Virginia
Thanks,
Chuck in Virginia
