I have a bad solder joint in a 1/2-inch copper line, at a coupling. Pin-hole spray of water. There are convenient shut-off valves to isolate the section of line, but the pipe is full of water. I think I have to cut the line, drain the water, and then re-fit and re-solder. Is that right?
