Jeremy Thacker
Wrapping up a home addition and a last minute addition of a tub caused a change in location of our fixed glass shower panel. The glass slips into a painted stainless steel u channel that is meant to be attached to a wall one one side and the floor with the top and other side not connected.
With the addition of the tub, we decided to put the glass panel at the rear of shower not connected to the wall. Instead, I bought two 1" square steel tubes that I'm going to anchor to the floor and ceiling. The glass panel will be anchored to the steel tubes using the original u channel.
I've already had both the u channel and the tubes powder coated prior to me knowing about galvanic corrosion. My questions are:
Is the powdercoat alone enough to prevent corrosion?
If not, what's the easiest way to prevent corrosion? Nylon washers, sum buffering strip?
What is best type of anchor to use?
