Atypical Kohler Diverter in base of tub spout....doesn't pull out, is this going to be a problem to remove?
California
Older Kohler diverter which is in a tub, if you pull up on the valve it does not give, it turns, but only if you have the water on, will it only slightly divert water to the showerhead. I am having a time trying to find this on the web , but am asking if you have any ideas on if this difficult to budge diverter is gonna be so hard to remove that I may need to get it out in pieces....
Anyone see this configuration where the diverter is in the base instead of the tip of the spout..
Any observations or advice is appreciated
Thanks in advance
Wow! I've never seen a wood tub like that. And I can't find a picture of that tub spout either to see if I can pull up a parts page on it.
California
Thanks, it was made by a master Italian keg cooper when the place was built in 1980, Colorado , Its a Kohler product (Imprinted on the fixture) , the diverter valve , I am assuming should pull up to engage the shower, but it hardly budges......and to get any water to come out of the shower head, you have to pull on it while the water is on and only a minimal amount comes out of the shower head. I realize the allen screw needs to be loosened to remove the knob and then unscrew the entire assembly. Its just that at this point, it may be so crudded up w scale, I dare not even attempt to remove it unless I am sure I can get a part to repair this....
Marlinman
Jacksonville Florida
Kohler Alterna K-6942. The cartridge is discontinued by kohler but is reproduced by the Jerich company # 21475
I hope I'm not messing this up. I'm trying. I love that you know this stuff Marlinman, I couldn't figure any of this out. TL
California
Wow I am totally impressed that someone has archives that can pull up OLD plumbing w an equivalent that can be used.....I went to ebay and they have what appears to be a genuine old stock valve..... If the local plumbing supply place cannot find a Jerich equivalent, the old Ebay OEM may be a good equivalent.
California
So, this is the big question, if the diverter valve is so unmovable that it marginally moves, is this going to be a big endeavor to remove and replace with a new part... like having to pull it out in pieces ?
Thanks for sharing any past experience with similar replacements
Marlinman
This diverter cartridge seals on an o-ring to the spout body. An adjustable (Cresent) wrench should remove it with just some resistance. You can always have another person to hold the spout from turning if that is a issue.
