Assistance with 5810SXT settings
Avionixx
Georgetown, TX
Hi all,
Long time reader, first time poster. Finally got around to buying a softener and now I need assistance with the settings before firing it up.
Usage: 140 gal (currently only 2 adults at 70 gal/person, but house has 5 full baths)
Valve: 5810SXT
Resin tank: 12x48
Resin: 2 cuft 10% crosslinked (CR10)
.25 gpm
.75 Salt Lb/Min
Injector 1
14 gpg hardness from Hach 5B kit
City Water
Please let me know if any additional info is needed, thank you in advance!
This uses the automatic reserve adapting. If you want a fixed 140 gallon reserve instead, let me know.
Glad to see you have the #1 white injector.
System info (not programmed)
salt lb/cuft : 7.5 ; A choice ( efficiency vs capacity)
BLFC : 0.25 ; Brine Refill rate GPM
cubic ft resin : 2 ; Same as (nominal grains/32,000)
Raw hardness : 14 ; including iron etc
Estimated gal/day ; 170 ; 60 gal per person prediction (auto-tunes)
Est days/regen ; 18.07 ; presuming days each use estimated
Fleck 5810SXT Settings:
DF = Gal ; Units
VT = 5810 ; Valve type
RF = dF2b ; Downflow, Double Backwash
CT = Fd ; Meter Delayed regen trigger
C = 46.1 ; capacity in 1000 grains
H = 15 ; Hardness grains after comp factor
RS = cr ; Cr = base reserve on recent experience
DO = 30 ; Day Override (typ 30 if no iron/Mn)
RT = 2:00 ; Regen time (default 2 AM)
B1 = 5 ; Backwash 1 (minutes) [3...10]
Bd = 60 ; Brine draw minutes
B2 = 4 ; Backwash 2 (minutes)[3...10]
RR = 6 ; Rapid Rinse minutes
BF = 20 ; Brine fill minutes
FM = t1.2 (usual) ; t1.2 is default flow meter
RE = OFF ; Relay
VR = OFF ; ?
