Willy said:
I think I have the concept for the tablets. You have to move the water back and forth across the screen to disolve the tablets and to get the acid to work all the way through and around the screen.
Yes, that is essentially correct. Consider again some (and actually all) of what SpeedBump has said:
speedbump said:
The well must be able to drink some water to put the solution out into the material around the screen which is also plugged with iron, sulphur, hardness etc. ...
Once the solution gets to a saturation point, no more pellets are going to dissolve until more water is induced.
If you have any flow at all coming out now, that means your well will be able to "drink some water" if you force some in against its natural pressure and flow. So, you need to first evacuate as much as 10 or 15 minutes of "free time" (before the casing again fills), if possible, for introducing the pellets. Then after the pellets are in and the well is capped and everything sits for a few hours (or even overnight), you need to be able to force some clean water into the well and attempt to surge it down and back up for a while.
Are you very handy at "making things happen"?
Later this evening or tomorrow I can try to write this out in more detail if necessary, but if I was doing that work on your well, I would cap your well (when it is time) with a tee configured to do everything you need to do ...
Rig your regular water pump and pressure tank to force a few gallons of your cinstern water through a check valve going into a tee on the top of your well, then stop that flow and open a valve at the other port of that tee to release about the same amount of water from the well casing. The water you let back out will be the water you first forced in, so you will only need to use common-sense precautions there. But in doing that, you will be agitating and surging the acid and whatever at the bottom of your well ... and after going to all this work to set everything up, I would do that like every 15 minutes for 3 or 4 hours before opening the valve at the tee for the final time to see whether your well is going to again produce and flush itself.
Also, what Bob said about sticking something like a long 1" pipe (open on the end) to the bottom of your well to then "inject a high flow of water" would be a great way to give your well a good flush to remove all the little chunks of scale from the bottom after it has been cleared. Looking back, I now see (from the sediment in my filter housing) that I should have also done that myself a couple of months or so ago. I have never actually seen that done, but I believe that is the "jetting" you should probably not do until after the acid has been naturally pushed back up and out of your well.
