Arrowhead BK1390, Non Standard Vacuum Breaker
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Kub, Jul 5, 2006.
  1. toolaholic
    toolaholic General Contractor Carpenter
    Jul 16, 2005
    Repairing and remodeling homes
    Marin Co. Ca.
    life is soo short
    why screw with an old ,or new hose bib ?
    buy a new on for god's sake:rolleyes:
  2. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    LOL!! He might have to.....I finally found the internals to the same faucet. Found it at a supply house in Cincinnati. Had to bring an AK-47 just for protection but I made it out alive!!!!! :eek:
  3. georgegraz
    georgegraz New Member
    Oct 9, 2005
    I just went through this a couple of weeks back. With the help of this forum, I found the manufacturer's name. I called them and within a few days replacement part - NO CHARGE -. I just unscrewd the old one and screwed in the new one. Much easier then trying to reach around the cold air return and fight with the piping to replace whole bib.
    George
  4. toolaholic
    Jul 16, 2005
    Marin Co. Ca.
    like I said George
    fix the old one Tool :rolleyes:
  5. dubldare
    dubldare Plumber/Gasfitter
    Sep 14, 2005
    Plumber/Gasfitter
    MN/ND
  6. violet2christi
    violet2christi New Member
    Jun 26, 2010
    Tulsa, OK
    I know it's been awhile since you've had this problem with a replacement for a leaking vacuum breaker, but what did you end up doing? I have exactly the same faucet (as the one shown in the pic you posted) and the vacuum breaker shown above. Thanks.
  7. mdietz39
    mdietz39 New Member
    Aug 14, 2011
    Albuquerque, New Mexico, USA
    Replace freezeless adapter on outdoor faucet
    We have outdoor faucets which do not have a garden hose thread. They require an adapter to attach a hose. The only adapter we have locally are a freezeless type which starts to leak after a year or two. Is there an adapter which is just solid, without all the stuff to drain the line etc., to adapt the faucet to take a garden hose?
    Thank you for your time and attention to this.
    Mike
  8. jadnashua
    Buy better quality hose bibs! Those are frost-free hose bibs, and they require the vacuum breaker to work, unless I'm all wet. Maybe a picture of what you have would help clarify the situation, but no, don't think there's another way. A frost-free hose bib does three things: has a built-in vacuum breaker to prevent accidentially sucking in contaminated water and polluting your water supply, automatically drains to prevent the pipe from bursting (only works on most if you remember to remove the hose when it freezes - this may be why it fails so often), and last, turns the water on and off. Some are built better than others, but if over the winter, you leave the hose on, unless you buy a whole new faucet that won't be damaged, you HAVE to remove the hose when it freezes, or things will break.
  9. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    I think what you are referring to is you have standard hose bibs with a vacuum breaker attached. The vacuum breaker is there for all the reasons jadnashua gave.
    John
    [​IMG]
    [​IMG]
  10. jadnashua
    ABQ does freeze on occasion...the vacuum breaker is the weak point, and is the first thing to go if there's a hose on the bib and it does freeze.
  11. mdietz39
    mdietz39 New Member
    Aug 14, 2011
    Yes it does freeze here, we actually live in the mountains outside of Albuquerque. -28 degrees this winter but that set all kinds of records. Normally it will get down to about 10 degrees above zero, maybe. However another of these pieces of junk just started leaking today. It has been above 65 degrees every day for months, hitting up to 101 during the day. So it did not freeze. They just fail. I turn the water on and there is a leak above the hose in the recess of the adapter. I think the internal working eventually fails.
    As far as replacing the bib, that will cost around $250 each and we have five of them. Plus it means cutting into the interior wall with all the patching needed for four of them, one of which requires removing the kitchen sink and cabinet to get to the pipe. BUMMER.
  12. hj
    WE would need a picture of your faucets. ALL outdoor faucets should have hose threads on them. There is no such thing as a "freezeless adapter". There are vacuum breaker attachments, and sometimes a faucet needs a "special" one from the manufacturer for that specific faucet, in which case the faucet itself would not have the hose threads on it, but that would be by the intent of the manufacturer.
  13. hj
    quote; The kind your talking about should be available at hardware stores and any good plumber should have one or two on hand.
    I am a good plumber and I have ZERO proprietary vacuum breakers on the truck. The only plumbers who would have them are those who are in area with a multitude of that particular brand, so that they encounter the situation frequently. That is NOT the case in this area.
  14. Terry
    Aug 17, 2004
    Arrowhead has new outdoor faucets with built-in vacuum breakers.
    [video=youtube_share;g7Z2cd4AbKw]http://youtu.be/g7Z2cd4AbKw[/video]
  15. JCturboT
    JCturboT Member
    Mar 9, 2007
    Massachusetts
    Terry/Anybody,
    Have anyone installed these new Arrowhead Brass units? What are your opinion on them?
    http://www.arrowheadbrass.com/op_ch...TechSheet/Arrow-BreakerComboTechSheet_2Pg.pdf
    I might be interested in updating some of my older AB units and these seem real nice.
    Jeff
Similar Threads: Arrowhead BK1390
Plumbing Forum, Professional & DIY Advice Arrowhead PK1390 Vacuum Breaker for hosebib. Not being shipped. Jul 25, 2017
Plumbing Forum, Professional & DIY Advice Arrowhead Freeze Proof Faucet Questions Nov 10, 2010
Plumbing Forum, Professional & DIY Advice Replacing Arrowhead Frost proof Faucet Jun 9, 2010
