DavidTu
Regarding installing a tailpiece extension... originally I had the type of slip-joint that has the plastic wedge shaped washer, which I assume operates by compression. In this case the tailpiece not having any sort of flange seemed fine. However, I got a replacement p-trap and it has squared rubber washers instead of the wedged plastic and so I am wondering if this type of joint requires a flange on the tailpiece (similar to the one on the portion of p-trap that goes into the wall). Or can both the wedge and the squared rubber work on a flange-less tube?
Thanks!!
Thanks!!
