gadolphus32
I'm planning to replace all of the cold and hot water supply lines in my basement. Currently, the supply coming into the house is 3/4 inch copper. Right after the main shutoff, it goes down to 1/2 inch, and all the other pipes in the house are 1/2 inch.
My main reason for replacing the pipes is to reduce lead in the water (on that, see below) but the water flow in my house is also a little weaker than I would like. In the hope of improving it, I plan to replace the 1/2 inch pipes with 3/4 inch as much as possible.
I'm not going to replace the pipes in the finished parts of the house. Those will still be 1/2 inch. I'm just replacing the exposed pipes in the basement. I'll reduce everything down to 1/2 inch where it goes upstairs.
I'm wondering if there is any reason *not* to want to have 3/4 inch rather than 1/2 inch lines. Apart from the slightly higher cost of 3/4 inch pipes and fittings, I can't think of any obvious disadvantage, but I'm also not a professional plumber.
In case it matters, the pipes are currently all copper. I'll replace them with Pex. The replacement is motivated by a desire to reduce lead levels in my water, which tested higher than acceptable even though we do not have lead pipes. I suspect the 100-year-old solder is the culprit, and I hope that by replacing as much piping as I can with Pex, I'll be able to reduce the lead levels significantly.
