Bob from accounting
I watched a plumber apply flux to a freshly soldered joint. He had soldered a 1 1/4" ball valve, he went back around the entire joint and applied a healthy amount of flux all around the freshly soldered joint with the torch fully on, so an outer layer of flux coated over the new hot joint.
So he cleaned, fluxed, torched, applied solder, than went back and torched it back up and applied like a finishing coat of flux over everything with the heat on and this second coat of flux was brushed thoroughly over streaming hot joints?
Is this common to do after the fact?
