Frank Aaberg
New here so I'll have some probably pretty stupid questions!
Any difference between Wirsbo hePex and the stuff Me**rds sells called Sioux Chief "Pex-A"? If it helps, the Me**rds site says it is:
EDIT: I should add that this will be used for radiant floors.
EDIT 2: I'm also seeing they have 1/2"X300' PEX-A OXY BARRIER @ $116. Maybe this stuff is a better comparable?
- For use with PowerPEX™ A Fittings
- Compatible with all F1960 PEX Expansion Systems
