DavidTu
I need an ASSE 1070 compliant mixing valve at point of use for a free-standing slipper tub supply (3/4" supply lines btw). What products are recommended? The supplies are to be floor-mounted; how have you handled access for the valve in this scenario (I am thinking about building a box above the floor onto which the free-standing supplies can mount and within which would be the valve... other ideas?)
What is most cost-effective way to meet the requirements (see below)... perhaps a ASSE 1016 valve is less expensive, though seemingly more advanced?
Seattle/King Country Director's Ruling:
http://www.google.com/url?sa=t&rct=...tYGoCQ&usg=AFQjCNFR2eZf2-6r6h2ZpBGbNLebHZLa8g
Does this work? http://www.grohe.com/us/5750/search...roduct=35204-G217&color=000&material=35204000
we have 3/4" supply lines running... will it hurt much to reduce to 1/2" at the valve and then 1/2" supply from there or does that remove the benefit of the 3/4" dedicated supply lines? OR is there a 3/4" version of this valve or similar? (Again, this is not to protect from thermal shock, just scalding so Seattle / King County only requires ASSE 1070 but ASSE 1016 options would work as well--was assuming ASSE 1070 would be cheaper, but maybe not if too uncommon)
Here is an old thread I tried to resurrect but I didn't see it in the Forum so reposting here. https://terrylove.com/forums/index.php?posts/429184/
