Jazzman
Hi there,
I’m installing a roof top tv antenna in an attempt to “cut the cord” from the cost of cable. I’m a little stuck in the best practice for safely grounding it. Unfortunately the main equipment ground is about 100 feet away and I’ve been finding conflicting info about adding a 2nd ground or just running a long ground wire to the main equipment ground. The 2nd ground rod would also be tied in to the house ground rod. The only access is through the crawl space,
Thanks for any input!
