Hey guys was hoping for some advice. One of my rental properties is on well water it's actually four rentals on the same property and they all share the same well. The water is softened and is actually crystal clear with very low iron and odor but run it through a water heater and that's another story. The longer it sits in the water heater the worse it gets and my tenants are complaining that it's unbearable. I can drain the water heater but the smell is back within a matter of days. I have four separate water heaters for the four separate rentals and I just replaced all of the anodes which were completely gone with new aluminum ones from Home Depot and now the smell is back and worse than ever. They were approximately 4 years old. So my question is what if anything can be done about this order. Can you use a water heater without an anode and if so how long could you expect that water heater to last? I might be willing to go that route to forego the horrific odor. And finally could this be a grounding or bonding problem with the heaters?
