From what I've read, most of the CSV's reduce pump flow to around 1 GPM when the pump discharge is fully throttled. Unfortunately, newer pumps seem to have higher minimum flow requiremts.
Is it better to find a CSV that meets the minimum flow requirements, or would a properly sized bypass orifice work to provide the minimum required flow when the CSV is fully closed? I don't want to buy a bigger valve if it isn't needed!
