YankeeFaninPhilly
Hello and Merry Christmas!
I have read a lot of posts in here - great site - thank you everyone. I have read dozens of venting posts to see if I can answer the question.
I am a DIY homeowner/engineer that has done a lot of plumbing and construction work over the years with new bathrooms, finishing basements, etc - I guess it means I move too much! However, I am stumped a bit here.
The basement has been stubbed out with (2) 4" lines that feed a poly pit for an sewage pit just 3 feet away. Unfortunately, the two stubs are less than 12" apart, and not enough room with the pit and pipes to do anything "as is"! The choice is to dig up concrete or build a floor. Since we have 9' 6" ceilings, we are building a 2 x 8 floor, and can then run the drain lines where we need to. There are 4 other toilets in the house that all work great, with 3 separate roof vent stacks from what I can see.
I am putting in a corner shower, toilet and sink (6 DFU's I believe). I plan to use a Zoeller M803 residential grinder for the pump with a check valve (any recommendation for a good, quiet one?).
Big challenge is that there is no way to vent these fixtures outside since we are not near any vent stacks on the first floor above - Everything nearby are horizontal drain lines heading to the main sewer pipe, which I don't believe qualifies as venting for new fixtures.
The local inspector said they would allow air admittance valve(s) as long as it/they were sized properly.
If I put an air admittance valve on the vent line for the pit, will that allow enough air to flow through the rest of the system? The Studor Redi-Vent 1 1/2 says it handles 6 DFU, but I feel like the Maxi-Vent would be"better". The pit is less than 10 feet away from the toilet and shower if that helps.
Every diagram I see for an ejector pump/pit shows its own vent line, and then the fixtures still have their own vent as well. I have pictures of the area, but not sure I am uploading properly
Any help would be most appreciated.
