RayN
I am draining the water heater today. Its a Rheem 50 Gallon Gas Model 2250F1. It will be 5 years in March 2018 and I have never drained it. I finally got it to drain, but that is another story.
I have a replacement flex anode rod (https://www.homedepot.com/p/Rheem-P...ctric-and-Gas-Water-Heaters-SP8371B/205652259) which is 10 inch longer.
The original was 44 inches solid and the new ones is flex 54". Each of the solid element is 12" long and there are 4 elements connected by a cable, so total 48" worth of magnesium. I think it will still fit as is, and I guess the lower portion will just lay in there at the bottom. Is that acceptable?
Should I me cutting the bottom piece to account for 44" or should I leave its as is or cut to some other in between length? You input will be appreciated.
