DoubleB
My master bedroom shower sprung a leak, found out the cartridge and the pressure balancing needed to be change. It was very difficult to take out the balancing part. Had to use angle pliers and a screwdriver to take it out.
Replaced the part and no leaks!
Felt real proud...
Decided to be pro-active and replace the main bathroom shower valve cart and balancing. This was 10X more difficult, limited space inside the shower insert. No service panel.
Finally, got it out replaced the parts, no leaks when the water is turned back on. When I turn the faucet, water drips between the valve body and the balancing part.
I think I messed up ...
I scuffed up the edge of the valve body while taking out the pressure balancing part. And I believe the balancing part seal is not sealing.
Is there a way to patch this up or do I need a new valve body. I will post some pictures later.
My plan when I get home is to use some sand paper and try to buff the edges to see if it will seal properly.
These are the parts I have: https://assets.supply.com/ul_pdfs/416250_partsspecs.pdf
Any help is greatly appreciated,
Brian
Felt real proud...
Brian
