Peter O
I have a American Standard Push-Pull shower valve which was installed in 1967. I am experiencing a reduced hot water flow rate relative to the cold water rate. I verified that the hot and cold flow rates are identical on the sink faucet in the same bathroom. What is causing this? I have attached a picture of the valve. If I purchase a rebuilding kit would this correct the problem? If so does the kit come with instructions or do I just remove the two screws on the front and then replace all the parts?
