argo
First off - Thank You for sharing your knowledge and experience; your site is invaluable to me.
1. I am in the process of replacing a 20-year-old bath tub with American Standard' Americast bath tub. The new tub has a rigid 1/4" foam through out its bottom. Will it be safe to install the drain gasket in the following fashion: (from bottom up) >> plastic drain > rubber gasket > tub's rigid foam > plumber's putty under screw-in pop-up drain. Is it better to use a thin rubber gasket or plumber’s putty? Also, should I silicone all of the joints on the drain assembly - just in case.
2. Because of the extra thickness that the rigid insulation adds the overflow gasket doesn't fit into tub's overflow opening unless I remove the gasket's lip facing the inside of the tub. Could I simply silicone the inside of the trim piece instead and secure it to the overflow drain pipe.
Thank you. Arthur
Thank you. Arthur
