Aluminosilicate-based Iron Filter?
J.A.R.V.I.S.
Michigan
I'm trying to decide which system to get for iron removal and came across this one. It uses an aluminosilicate-based media, and I didn't see anything about that type of system on here. Pros? Cons?
J.A.R.V.I.S.
Michigan
Lab test report?
Water Test Results:
Aluminum 3.57 ug/L
________________________
Antimony 0.00 ug/L
Barium 407.11 ug/L
Berylium 0.00 ug/L
Bicarbonate 275.85 mg/L
Cadmium (Cd) 0.01 ug/L
Calcium 51.91 mg/L
Carbonate NM
Chloride 5.09 mg/L
Chromium 3.83 ug/L
Color 18.63 color SM2120C, 21Ed
Color after Acidification 2.34 color SM2120C,21Ed
Conductivity 1301.10 microS/cm
Copper (Cu) 0.0000 mg/L
Est TDS By Conductivity 796.10 mg/L
Fluoride 0.61 mg/L
Hardness (CaCO3) 241.43 mg/L
Iron (Fe) 0.90 mg/L
Lead (Pb) 0.01 ug/L
Magnesium 27.10 mg/L
Manganese (Mn) 0.01 mg/L
Nitrate as N 0.13 mg/L
Nitrite as N 0.00 mg/L
pH 7.92
Potassium 2.52 mg/L
Selenium (Se) 1.37 ug/L
Silica 15.44 mg/L
Silver (Ag) 0.00 ug/L
Sodium 173.56 mg/L
Strontium (Sr) 0.81 mg/L
Sulfate 11.78 mg/L
Tannins 0.40 mg/L
Thallium (Tl) 0.00 ug/L
Total Arsenic 0.00 ug/L
Turbidity 4.56 NTU
Turbidity Filtered 1.65 NTU
Zinc (Zn) 0.00 mg/L
J.A.R.V.I.S.
Michigan
Here's the other one I'm considering, Pentair. It's like 3x the cost, but a traditional air-injection type. Which one should I go with?
ditttohead
Water systems designer, R&D
Ontario California
Neither... that is an old Erie 2000 valve, looks like Pentair is repurposing it for AIO? Odd but sure. AIO can create a lot of problems, primarily iron bacterial issues. Adding an ozone generator is highly recommended. This way the system is partially sanitized daily during the regen process.
J.A.R.V.I.S.
Michigan
Neither... that is an old Erie 2000 valve, looks like Pentair is repurposing it for AIO? Odd but sure. AIO can create a lot of problems, primarily iron bacterial issues. Adding an ozone generator is highly recommended. This way the system is partially sanitized daily during the regen process. View attachment 75405
What is your preferred type of iron reduction system?
J.A.R.V.I.S.
Michigan
