ditttohead
Water systems designer, R&D
Actually, your question is excellent and is often ignored and can cause problems.
In general, the softener resin makes a poor sediment filter. Most of the smaller sediment will go right through the resin bed. Very large sediment will get caught up in the top screen of the system. The flow rate at the top screen is in excess of 50 GPM per Sq. Ft. so it is easily expelled during the backwash cycle. The sediment that tends to make it through the top screen but does not go through the resin is usually fairly light. The backwash rate of the softener mineral tank is about 5 GPM per square foot, which will cause the resin to expand approximately 30% to aid in cleaning of the resin bed. This is why standard units will have a 50% free board (1/3 of the bed depth).
I hope this helps.
The problem occurs with high loads of sediment, this should be filtered out, or larger heavy sediment and no top screen. The
I hope this helps.
