The expansion tank is the point in the system where the pressure does not change ...
I just had to install a new thermal expansion tank myself since the old one failed on Friday afternoon and you can't get a plumber until Monday unless you want to pay an arm and a leg for emergency services.
Anyway, the above quote from an old thread has me a bit concerned. To figure the air pressure, I temporarily installed the water pressure meter on the pipe where the old expansion tank was. I notice that if you run the hot water, the pressure drops, as one would expect. So is this normal, or maybe I am taking the above quote on the old thread that water pressure should never change somehow out of context?
Also, the value of the water pressure has concerned me. Most people are saying it is normally 50-60 psi. However, I measured 125 psi at the garden hose and 121 psi at the expansion tank connection. Both readings taken when I was as certain as possible that nobody was running the water. These values are double what others are saying. It's a brand new water pressure meter and came with the manufacturer's accuracy test results (measured within 1 psi at higher pressures this). Is this high water pressure possible in some locations, or am I maybe somehow taking the reading wrong?
Finally, how close does the air pressure really have to be exactly equal to the water pressure? I imagine the air pressure in the expansion tank normally changes somewhat with the weather (high vs. low pressure storm systems)? I think I got it pretty close to 125 psi, at least no more off than +5 psi, but is a value that is slightly off like this enough to cause a problem or cause the expansion tank to fail prematurely? Can I check the current air pressure or add/release air in the expansion tank (without removing it) by shutting off the cold water and letting the sinks run till they stop?
