Pr0t0c01
Hey again, so my situation with my well seems to be steady, running better than a few months ago, but it still runs out eventually. In an effort to avoid spending $3k having a 6" well put in, I'd like to try running a single tube with a compressed air hose in it down to bottom to create an air lift to clean out lots of silt that is at the bottom. I'm hoping this will help it's recovery.
The issue I have is how you seal the casing and branch out to a hose that will have your dirty water going out. This is located inside my garage to make matters worse, so I wanted to seal it at the top of the casing which has threads.
Is there a good solution to this, any combination of parts or a premade piece for this purpose? I'd imagine a seal with 2 holes out the top that are sealed would do the trick. 1 for the compressed air in, one for the out hose?
