We've struggled with air in our water lines for quite some time now. We have a well water system and ongoing problems with iron in the system as well (and associated smell in the water).
The picture shows the main plumbing of our system;
As you can see, we have an air injection venturi pulling air into the system directly from the well. The water then goes to the pressure tank, up through the pressure sensor for the well pump, then up and around through to the first stage of the iron filter with the air vent on top. This air vent is supposed to vent off excess air from the system. The system then goes on to another iron filter tank and then the water softener, water heater tank, etc.
Problems;
1. There is usually air in the system somewhere causing one of our inside water faucets (usually the one directly upstairs from the system which is in the basement) to blast out air along with water once in a while. Annoying at best. This would lead me to suspect that the vent is not working properly but it seems to work fine. In fact there is another similar vent just before the water softener which works but never vents air.
2. As mentioned, we often - I'd say usually - have problems with our water smelling 'earthy'. I've 'shocked' the well several times with bleach and that helps for a little while (anywhere from days to months) and then the smell comes back. I don't know if this is related to the air in the lines but...
Anything obvious come to mind, either from the picture above or from what I've described? I've had our plumber back many times and he doesn't seem to solve the problem. Also had a water 'specialist'. Same non-results.
We have high-iron groundwater and this system is supposed to take care of it.
Any help would be appreciated.
Problems;
