dackpockity
Hey everyone, I’m having water issues in a new home we just built . Basically I’m having fairly bad air sputtering at all faucets and showers . Bit of a story here but I’ll give all the info I can. When we purchased the lot the well depth was 205ft and the paperwork rated it at 1gpm. I purchased a 1/2 hp 8gpm submersible pump and 1800 gallon tank for storage and began pumping the well. I realized once we were running we were only getting about .25gpm . This wasn’t going to work so we had a driller come drill the well to 315ft and now have around 15gpm. So I dropped the same pump to 250ft and now have 1 inch black poly from the pump up to the pitless with a check valve half way roughly. From the pitless I have 1.25 pvc to the pressure tank 300ft from the well in my crawl space. Static head in the well is 20ft .
So far I’ve tested the air pressure in the bladder, shut off the valve on the house end of the pressure tank and the gauge remained steady at 60psi. I do have a small drip under one of the fittings once every couple of minutes on the pvc to brass fitting under the pressure tank but that’s the only thing I can see wrong with the whole system. The pitless adapter doesn’t appear to be leaking and I can’t hear anything in the well that would indicated air getting in or leaking. I’m going to take care of the small drip in the fitting under the pressure tank tomorrow but it seems like a lot of air is entering from somewhere. My well pump is also undersized I believe but I’m trying to make it work for now. Any ideas where the air would be coming from? One thing I should add is that my electrician Initially wired the system wrong and caused the system to pressurize to the point that the valve on the pressure tank was forced to open because of the excess water pressure. This was the reason I drained all the water and checked the bladder .
