AIO Rinse issues
acherry
yes
Hi everyone, hoping someone can help me diagnose this strange issue.
I converted an older Fleck 5600 AIO system into a Katalox Light AIO. The install went fine, gravel + 1.5 cu ft KL, new piston and new seals/spacers in the valve head. I expected the pH to go up at first, but after 1.5 months it still stayed around 9.3, so I started digging into what’s actually happening during regeneration.
Here’s the core problem:
When the system finishes Air-Draw and enters Rapid Rinse, it initially sends water to drain, but after a few seconds the drain flow collapses to a trickle or stops completely.
If I push the piston manually downward while it’s in the Rapid Rinse position, the drain flow becomes full-force, almost as strong as the Backwash flow. As soon as I let go, it drops back to a trickle.
Additional symptoms and observations:
  • Backwash is strong and consistent (full upflow, good lift, strong turbulence).
  • The piston makes a sharp “pop” when shifting into Rapid Rinse, as if it’s being pushed up by pressure.
  • After disabling air draw and running multiple BW→RR cycles, pH dropped slightly (9.38 → 9.13), so the bed is collapsing somewhat.
  • But the Rapid Rinse still only works when I manually push the piston.
At this point I’m unsure whether the issue is:
  • A downflow restriction in the valve throat
  • A partially rolled or mis-seated seal (new seals on an old valve body)
  • Foreign material lodged in the downflow port
  • The piston riding incorrectly on the seal land
  • Or some remaining air / hydraulic backpressure in the media bed
Any insights would be really appreciated — I’m pretty deep into this one and could use expert eyes.
