AIO Iron Filter Regeneration Settings
MOTC
Michigan
Hi All,
I have well water with about 4.5 ppm of Iron. Five Days ago, I replaced my AIO Iron Filter with the same exact model, but supposedly it has different media (no one seems to be able to tell me exactly what media, but I found out it is made by AquaSystems, so I might give them a call to try and find out. It seems it has a mixed media. I don't think it is anything special. And anything that they call "special" is probably just a sales technique.)
The iron in the water is ~1.5 ppm of Ferrous and ~3.0 ppm Ferric (just using those test kits that the water softener installers use -- not sure if that is accurate enough.) My last Iron Filter "lasted" 5 years. I am trying to "optimize" the regeneration cycle on my new filter, if such a thing can even be done. My regeneration settings on my last unit were: 9 minutes Backwash, 6 minutes Rinse and 30 minutes Air Draw. The tech I worked with said that the new media was much heavier, so he suggested a 12 minute BW, 8 minute Rinse (to settle the media) and 15 minute Air Draw (he thought it didn't need such a long air intake).
In reading all of the manuals I could find, the Rinse Cycle seems to be the most variable. Some mention the Rapid Rinse for 1 minute at the end. Most eliminated it altogether. The tech I spoke with at length felt that the Rinse was essential to getting the media packed down after the the Backwash. What was also interesting was that he suggested that I might not even need the Air Intake, as the 1.5 ppm of the Ferrous should be able to be handled by the Kinetico 2060 Water Softener without a problem. I can "logically" follow what he is saying, but it is contrary to everything I have read. Is this an idea you have heard before?
Perhaps 4-5 years on a unit is pretty normal. The sales people will tell you it will last "10 years, no problem".
So, my questions revolves around the "optimal" regeneration cycle for my situation. We regenerate every 2 days. We use anywhere from 350 to 500 gallons over the two days. Is there a suggested Minimum and Maximum for the BW cycle? Is the rinse cycle needed? If so, how long should the Rinse Cycle be? How long should the Air Intake be? I do the Rinse before the Air Intake. If the Rinse is done after the Air Intake, does it really impact the air in a great way? I noticed tonight that there is plenty of air in my water when right out of the faucet, even at the end of the second day, but that's probably because the unit is brand new. Maybe I am splitting hairs, but I am an analytical type of person and it got me thinking about all of the variables, in order to try and keep the unit running well as long as possible.
Thanks in advance for any comments.
