Rockwind1
I recently had my "good" well on my 20 acre "ranch" start not functioning correctly,, turned out the well had started not producing as much. anyway,,,, I deepened the well to 680 ft. the static water level was sounded at 109ft deep before I deepened it ( I assume it is still the same) anyways, at 350 the well started producing 2 gpm. I went down to 680 ( expensive but my new Biden Bucks are so worthless I figured I would throw them down into a hole in the ground),, and hit hard stuff and it was still producing 2 gpm. (sad face) this well pumps water into a 2500 gallon black storage tank. there is a jet pump inside the well house next to the black water tank which then pumps the stored water to barn and other places. there is a system that turns the submersible pump on and off depending on water level in the tank. so it should be pumping about 2000-2300 gallons in to the tank every other day depending on usage of course.
when there are horses and people there I could see using 300-700 gallons a day. maybe more. I guess I could see the new submersible down at 670 ft running for 10-18 hours every other day if it ran at 2 gpm.
the local well company that drilled wants to use a franklin 3 phase 1.5hp 5gpm motor and a franklin 1.5hp 5 gpm pump ( is how it is written on estimate)
obviously I don't have 3 phase power at the property so this is a "sub drive" modulated motor which has a soft start capability and kind of runs itself based on a pressure sensor. 1" diameter schedule 120 PVC pipe and 12 guage pump wire. the guy wants to install a 5 gpm restrictor plate or (Dole valve) because at static water level, the pump will be pumping too much out of it's pump curve. it all makes sense to me, i like the "3 phase" motor idea.
what I don't get is why not restrict it to a 2 gpm restrictor valve because otherwise, I think the pump will out-pump the water in the hole and then be running dry for a bit before it shuts off. perhaps a timer is in order. I think maybe if a 5 gpm pump is restricted to pumping 2 gpm,, is that bad for the pump? is it out of it's pump curve? I don't know.
is it not possible to get a pump in the 2 gpm range at that depth?
has anyone put a "sub-drive pump in? happy with it?
I've read that the franklin pumps are not that great and the Grundfos pump is better,, is it possible to match a Grundfos with a franklin sub drive motor?
the other factor to consider is the power coming from my main power panel at the house is about 200-250 ft away,,,running, i think, #6 for about 30ft to a subpanel, and then about 220 ft of (#8) i think down to the pump house,, then about 40 ft of 12 guage or 10 guage from the old pump control box to the casing cap.
