HuckSTL
Has anyone seen this before?
I replaced rubber hoses with stainless braided ones on an older SpeedQueen washer. Everything worked find until I slide the unit back against the wall. That's when the AFCI breaker tripped.
There was also an upstream GFCI circuit that had a broken reset button (it never tripped), but I replaced it to assure it was good.
I tested again and if the stainless hoses touch the cabinet, the breaker will trip.
There's no voltage between the cabinet and hoses. I tested that but plan to test again.
What I suspect is that the chassis is grounding via the plumbing when it touches the stainless hoses. This triggers some sort of fault that the AFCI detects and trips.
I don't know if this is an overly sensitive AFCI or do I need to use rubber hoses to prevent grounding via the pipes.
I will see my master electrician friend later this week, but wanted to check if anyone has encountered this.
Note the unit worked fine with rubber hoses.
