Jason Bryan
We are redoing the well water treatment in the house we just purchased. Current setup has:
- Water inlet to Calcium Carbonate tank
- Flows to Katalox
- Flows to Softener
- Advice on this approach? Looking at continuous regeneration with Stenner pump and holding tank. Is there something "better" anyone has used?
- Where to put the injection and holding tank? Before or after calcium carbonate? Could the calcium carbonate tank act as a holding tank? It is backwashed, but the flow rate is not proper and needs to be addressed, but looks like it has been this way since the system was installed.
- I have seen some material saying KL does not need chemical treatment, only backwashing. Thoughts on that?
- Do plan on putting a carbon filter in to remove chlorine, but am targeting for after the H2S issue is resolved...meaning, I'm fine with some residual chlorine in the system for a bit (and will bypass softener while it is in there) to sanitize the inside plumbing.
