Hi there
I've got some major drain line issues,I'll try to explain this all as brief as I can. I moved into a house last September, and I have had the main drain line clog 4 times since moving in. I have had some plumbers come look at it and it has a number of issues with it and it needs some work. The flow goes as follows:
4 inch PVC from previous renovation into 4 inch cast iron for a 90 degree turn made by using two back to back 45s. After turn a secondary 4in cast line join main line. This secondary line comes through the foundation wall, on other side it's built on top of a slab with flooring over it, in other words it's inaccessible except the 8 inches on this side of the foundation. Moving on, the main 4 in cast line is then REDUCED to a 3 inch ABS pipe which goes through the front foundation wall. Outside after 4 ft it comes to a T junction which has a 3 inch clean out, and also swoops down where it connects to 3 or 4 inch concrete pipes which immediately S with two 90 degree angles and then goes one to connect to 6 inch concrete line which runs to street.
Phew! That's a lot of info, but here are the major issues I've been told I have.
1. 4-3inch reduction.
2. Back to back 90's at the bottom of the T.
3. T junction itself isn't the best.
4. Cast iron corner is a little tight.
Of the four clogs, one has been at the reduction and three have been at the two concrete 90's (I was told the PVC and concrete are a little offset which causes the issue.)
Here are my solutions from 2 different plumbers:
Local larger plumbing company guy: Fix everything from beginning 4 inch ABS out, replacing tight corner, reduction, T junction and S corners. Make longer corner inside, figure out a way to connect secondary old cast line to new ABS corner. Hope it doesn't break in to process. Cost 4000 bucks.
Plumber 2, small business, one man show: leave the cast corner and secondary cast connection as is. Not worth risking breaking secondary line because then I'm tearing up floor to get to replace that line, and I haven't had a specific problem with the corner. Replace everything after the corner, including reduction, T, and S. Cost if I do the digging 1200-1500 bucks. If he digs, highest end estimate of 3500 but probably closer to 3000.
I'll attach pics, mainly I need help deciding if replacing the corner is a priority or not a major issue right now. I'm trying to be economical with a baby on the way, but also want this taken care of! Any input is greatly appreciated!
