Theplayer11
I just had well dug 400'. I will use the well to water my greenhouse, no pressure tank. The well digger estimated around 12-15 GPM for the well, but did not test yet. He wants to order and install a Berkeley pump 200' down, The static level is 48'(I measured with fishing pole) First of all, Isn't the exact GMP needed to properly size the pump?
My watering needs:
1) fill a 1,500 gallon holding tank that is 100 feet away from well, 10' high, same ground level as the well. I will use a a standard 5/8 garden hose to fill. I then use a booster pump to water my greenhouses that are 200' long. I currently get about 8-10GPM from the end of hose with a standard 400 water breaker at hose end. The pressure is fine
2) If possible, water the greenhouses directly from the new well with standard 5/8 hose. The nearest greenhouse would use 200' of hose, the furthest 350'. I would like to get the same 8-10 GPM.
He is suggesting a 15GPM 1.5HP Berkely pump. I checked the pump curve and it's off the chart until 80ft, which would be 20GPM at zero PSI. How would I figure PSI I'm using to read the pump curve correctly? 200' would be 16.3GPM at zero psi, 14.4 at 20 PSI. My initial thought was that a 1.5 hp pump seems too high. My current well at 160' is using a 10GPM 1/2 HP Goulds pump.
Obviously, I don't want to over-pump the well. I could always tweak it down while filling the holding tank. Shouldn't he test the recovery rate of the water before ordering a pump?
Using the pump curves, it states "pumping depth in feet". That would be the water level, not the actual pump depth..correct?
Thoughts?
My watering needs:
Thoughts?
